Do you think it will make 300HP?
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
I built and am putting an '88 L98 im my '85 Sport Coupe. Specs are as follows:
.030 over, balanced and decked to about 9.2:1,Keith Black hypereutectic pistons/moly rings,World SR Torquer heads,Using stock TPI but port matched to heads and plenum, Adj. Fuel Press. Reg.,TPI airfoil, Cam is hyd. roller with .450/.480 lift., Edelbrock T.E.S. with Jet-Hot coating, 3" 3-way Catco catalytic converter, 3" Hooker cat-back system w/aerochamber, K&N air filters, TCI sizzler torque converter (500-800 above stock stall speed), 700R4 with high performance build up/shift kits etc.,
I shot for 300HP and 350 foot lbs. of torque.
Do you think I made it?
'85 Sport Coupe V6 T5(bought new)Putting in 88 350 TPI/AOD and a bunch of 88 IROC and aftermarket performance parts now.
86 IROC 305 TPI AOD
(selling after Sport Coupe rebuild is done)
86 IROC 305 TPI AOD
mustangman65_79
Aug 11, 2015 03:17 PM
