V6 to V8 swap Wiring Issues
Old Sep 25, 2009 | 06:18 PM
gurlmechanic12's Avatar
Car: 1987 firebird
Engine: A 350 4 barrel edelbrock carb & int
Transmission: 400
Axle/Gears: 10 bolt rear
hey, i am currently in the middle of a swap. The car im swapping into is a 1987 firebird that used to have a v6 fuel injected motor in it. I am trying to put a rebuilt 350 goodwrench motor (carbuerated) in it with a 700r4 tranny. Right now i hit a speed bump. i came to the wiring part of the project. I bought a parts 1986 camaro with a 305 h.o. in it. We took the wiring harness and computer out of that and had the intentions of putting it into the firebird but when we went to plug it in the plugs didnt match. so we consulted a wiring diagram but that didnt help because theyre completely different cars. so needless to say i need some advice on the situation. its a low budget project so i really dont want to buy a new harness. should i keep the old harness and computer? or how do i swap them...
thnx!
Old Sep 25, 2009 | 09:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: Pontiac V8 Swaps
ok, first you'll need to sell that crate engine & upgrade to Poncho standards. next you'll compare the 86 & 87 diagrams, re-read the v6-> sticky, & then have your post moved & this one deleted.
oh, welcome to the site.
Old Sep 26, 2009 | 01:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
gurlmechanic12, welcome aboard thirdgen.org.
Obviously you posted in a thread where your topic didn't belong, so I've moved it to its own thread.
You can use the V6 harness if you like. Some wires will have to be lengthened, some will have different ends than you need, but it can be done. A carbureted Goodwrench engine won't need (nor can it use) the computer. You will have to come up with some means of locking of the torque converter clutch without the computer. But, the things you will need such as ignition power, alternator wiring, gauges, starter, etc., don't go through the computer.
specialized
Jun 18, 2022 09:26 AM
midge54
Sep 2, 2020 07:13 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mizz0313
Aug 12, 2015 06:45 AM
