79 350 in a 91 RS T5, Flywheel question
Old Dec 17, 2000 | 10:27 PM
Macgyver's Avatar
Will a 1 piece main seal flywheel bolt to a 2 piece main crank?
IE: 91 Flywheel bolting to a 79 Crank?
If not, what flywheel do I use?
Shane McConnell
macgyver@nethirdgen.org [*]Webmaster of www.NEThirdgen.org[*]1991 RS 305 T5 15.6@88[*]1979 Z28 ZZ4/2004R (In the future.)
I'm the kinda guy you bring home to Mother.
Old Dec 17, 2000 | 11:29 PM
87Z-ya's Avatar
Nope sure wont. The 86 up flange is a smaller bolt circle, and it has a counter balance weight. If it is a 350 you need to get a early model 2 piece neutral balance flywheel. If your using a t5 make sure to get a 153 tooth. the 168 will not fit in the bellhousing.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Old Dec 18, 2000 | 04:39 AM
Novaguy76's Avatar
true, the 1 peice rear main seal flexplates will not bolt to a 2 peice rear main seal motor. If you are using an older block (2 peice rear main motor) then you will need to use a 305 flexplate and starter on it. I just went through this with my wifes car and let me tell you it was a nightmair. I ended up haveing to put an after market minni starter on the car just because i didn't knwo that these cars only had the small 305 flexplates on them. Don't make the same mistake I did.
Old Dec 18, 2000 | 10:54 AM
Macgyver's Avatar
I found the solution, an 83 LG4 flywheel, 153 tooth, 12 3/4" diameter 3 5/8" bolt pattern like the 79 350
Looks like I may have a 350 in the RS sooner than planned....
Pac J
May 17, 2020 10:44 AM
cheesehomer
Dec 31, 2015 08:48 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
monte87cortez
Sep 26, 2015 08:10 PM
