No spurt holes with chamferred bearings?
Old Dec 26, 2000 | 06:13 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
This may sound like a dumb question, but I had to get chamferred bearings for my 383 buildup and as I was installing the pistons I noticed there are no oil spurt holes in the rod bearings. Is this correct, or did I get a set of bearings which weren't completed? If there is not supposed to be an oil spurt hole in them can someone please explain why? Thanks.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
88CamZ
Oct 8, 2015 10:29 AM
drumstixer
Sep 29, 2015 03:02 PM
mfp189
Sep 27, 2015 09:25 AM
