Can I buy a crate 350 and...
Old Dec 20, 2000 | 03:20 PM
Hulk0202's Avatar
Can I buy a crate 350 and still use my computer, manifold etc.? What else will I need to get if I'm buying a basic crate 350 SB?
Old Dec 20, 2000 | 04:03 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Is your car carbed? either way you will need a new knock sensor and module, but we need more info.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Dec 20, 2000 | 11:17 PM
Hulk0202's Avatar
Sorry, I forgot to mention that it's a 305 TBI. Im not worried about emissions, and I'm going to take out all the AIR system equipment. I have limited funds so I would like to buy a good short block and use as much of my original equipment as possible. This way I can take my time and buy better components as I get the cash.
Old Dec 21, 2000 | 07:54 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
ok...this is going to sound a little weird, but here it is...
you can get new GM 350 for like 1500 bucks. now, you can also get a GM PERFORMANCE PARTS crate engine for only like 500 bucks more. i was looking into this when i replaced my 305 tbi.
this is an honest jump of like 80 horsepower and a lot of durability. (they are built more as a performance motor)
i thought it was worth it to spend a few hundred more dollars at the beginning and have a sweet engine, rather thna keep on upgrading an engine that wasnt built on as strong a foundation.
i think i said that wring, but for the little jump in money, you may want to check out the 350 HO crate motor. i kept my tbi and computer and all that crap. check out my web site here.
now, keeping costs as low as possible, check out the caprice 350 that is available from GM. it can still use your factory manifold and everything.
if you have any questions, let me know.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
[This message has been edited by Z28 Boy (edited December 21, 2000).]
Old Dec 26, 2000 | 05:49 PM
Josh 91RS's Avatar
Hey brian, what kind of times do you get with your setup? Im thinking of doing pretty much the same swap as you,and im just wondering what kind of times you get...thanks.
Old Dec 29, 2000 | 11:45 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Brian ,did you have any problem passing emissions with that engine?
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Eric-86sc
Aug 24, 2015 09:01 PM
