Major Question
Old Sep 30, 2009 | 05:08 PM
totalchaos's Avatar
Major Question
I have a 91 Camaro RS with a 305 Throttle body that I am going to put into an 86 Trans Am that had a 305 Tune Port in it. Am I going to have any problems with the wiring harness or CPU? Will it just slip right in without a hitch or do I need to change something? Thanks for any help you can offer.
Old Sep 30, 2009 | 05:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're putting the throttle body in the '86, you're going to have to change out all of the wiring.
If you're just putting the '91 longblock under the '86 TPI, the only issue will be the center intake manifold bolt angles.
Old Sep 30, 2009 | 05:46 PM
totalchaos's Avatar
Re: Major Question
so I am going to need to take the wiring harness out of the 91 and put it in the 86? What about the Computer will I need that as well?
Old Sep 30, 2009 | 09:23 PM
totalchaos's Avatar
Re: Major Question
That sucks I was under the impression that it was going to be just the motor swap. I have never dealt with wiring. How much of a headache is it??
Old Sep 30, 2009 | 10:20 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Re: Major Question
i
Old Oct 1, 2009 | 04:06 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Major Question
What's actually broken? no need to make more headaches (aka wiring swap) than necessary.
Old Oct 1, 2009 | 04:22 PM
five7kid's Avatar
As I said above, if you just change the engine, you won't have to change the wiring. You will have to change the intake manifold and deal with the bolt issue I talked about. Otherwise, the engine will bolt in under your existing '86 TPI.
If you put the "throttle body" induction system, engine, all of the stuff from the '91 into the '86, that's when you have to change the wiring, computer, etc.
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
