3.1 to 350 question
Old Oct 1, 2009 | 08:05 AM
tman1753's Avatar
Car: 1991 RS
Transmission: 350 turbo
3.1 to 350 question
I am swapping my 3.1 to a 350. Will my 350bolt to my 700r4 transmission?
admin wrote this in v6 sticky:
am i going to have any problems? as far as i knew, the 450 would bolt right up
If you are considering an engine swap in the pursuit of more power, please be aware that The RWD 60* iron-headed engines are the only DIRECT bolt in applications that fit 3rd Gen V6 F-bodies.
This includes the the following engines:
2.8L from the Fiero, Camaro, Firebird and TBI/Carb'd S10's
3.1L from the Camaro and Firebird (1990 - 1992)
3.4L from the Camaro and Firebird (1993 - 1994)
Old Oct 1, 2009 | 09:53 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 3.1 to 350 question
The 350 will NOT bolt up - that's why that info is in the sticky.
V6 trannies have a different bellhousing from V8, and I'm not sure they'll handle the power IF you did swap bellhousings.
Old Oct 1, 2009 | 09:13 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
they wont. some don't even last too long after a 3.4 swap
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
