need knock sensor part number please help
Old Dec 17, 2000 | 02:08 PM
gwman's Avatar
I just swaped from a 305 to a 350 in my 91RS and I need to change the knock sensor to a 350 one, and the module also.(what module I don't know). I looked at the online GM Performance calatog but can't find the part numbers anywhere or this module that I have to change. Can someone please help me!!!!!!!!
Old Dec 17, 2000 | 08:10 PM
MY85Z28's Avatar
Car: 1985 Z28
Engine: 383 forged, B&M 144 supercharger
Transmission: Art Carr 700 R4
Axle/Gears: 9 Bolt G92
The GM HO conversion LG$ to ZZ$ crate engine specifies the following part numbers
A.Knock sensor P/N10456018
B.Module elec. spark control P/N 16128261
Old Dec 19, 2000 | 11:54 PM
gwman's Avatar
Thanks for the info, but I'm not sure it is right. Only carburated models have a spark control module mine is TBI. So I'm not sure if the info you are giving me is correct for my 91. Any other Advice?
Old Dec 21, 2000 | 08:30 PM
87Z-ya's Avatar
Funny, my tpi and every other one ive seen from 89 down has a spark module.
Old Dec 27, 2000 | 07:56 PM
gwman's Avatar
I wasn't refering to the control module in the distributor. Every car with eletronic ignition has one. Is this the module that I have to change. If so why?
Old Dec 28, 2000 | 09:43 AM
87Z-ya's Avatar
No there is a module on the drivers side of the firewall. its called the esc module. Its behind some relays. But Dont know if tbi has it. If it has a knock sensor it should have one.
[This message has been edited by 87Z-ya (edited December 28, 2000).]
Old Jan 2, 2001 | 05:38 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
That is an IGNITION CONTROL MODULE. What you need is just the Knock Sensor, and yes that one posted will work.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
