84 z28 355-Long Tubes
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 84 z28 355-Long Tubes
There are only 2 choices, and both of them create problems. GM specifically designed that tapered "frame" under there just to prevent headers. EPA stuff. Anyway, Hooker makes a set of 1.75"-primaries, but if you're under 400 HP, use Hedman's 1.625"-primaries.
Transmission: 4L80E/4L80E
Flowtech also makes a set, but they're 1-1/2" primaries and from most reports, not very good quality (the Summit store brand headers are Flowtechs).
The Hedmans are a good choice.
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
