1992 rs motor swap
Old Oct 3, 2009 | 09:37 PM
erick 1992 rs's Avatar
Car: 1992 Camaro RS
Engine: 355 carb
Axle/Gears: 3.08
1992 rs motor swap
I bought a stock 1970's 350 4 bolt main this is my first rebuild i punched it .30 over I bought stock .30 over FT piston with valve reliefs replaced the stock cam with a hydrolic flat tappit .480 .480 lift 292 duration cam from paws i left the stock 76cc heads on it the casting number on the heads is 882 i also used a double roller chain, stock oil pump, 650 edelbrock carb and high rise intake can anybody tell me if the 882 heads are very good or what kind of hp i should expect from this motor
Old Oct 3, 2009 | 10:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 882's make excellent door stops.
Not too bad for bass boat anchors, either.
That's about it, though.
Old Oct 3, 2009 | 10:46 PM
Car: 1992 Camaro RS
Engine: 355 carb
Axle/Gears: 3.08
Re: 1992 rs motor swap
got any suggestion then i got about 450 i can play with
Old Oct 4, 2009 | 12:33 AM
five7kid's Avatar
Budget?
AFR 195's, GM Fast Burns, lots of choices out there.
Old Oct 4, 2009 | 01:25 AM
Car: 1992 Camaro RS
Engine: 355 carb
Axle/Gears: 3.08
Tight budget....growing family....plenty of time though. Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
355sbcTPI
Aug 19, 2015 04:38 PM
st.evel07
Aug 13, 2015 06:15 PM
