externally balanced 383 w/T-5
Old Jan 9, 2001 | 10:35 PM
jrob350's Avatar
I must use a 400 fly wheel(168 tooth) to balance my engine. I know a few 400's came w/a 4-speed but does anyone know of a clutch for my application.
Old Jan 10, 2001 | 02:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If this is a 3rd gen F car, forget it. That flywheel won't fit in your bell housing. And there's no "must" about it in any case.
I have an externally balanced 400 in my 83 5-speed car. I had to do 2 things:
1. Have a 153-tooth flywheel "unbalanced" at the balance shop to the stock 400 spec
2. Drill the correct hole in the block for the 153-tooth starter. Depending on your 350 block this may or may not be necessary.
Use the stock application of clutch. I happen to have a Centerforce Dual Friction in mine. It's what the book lists for a 83 Z28 5-speed.
Old Jan 11, 2001 | 10:13 PM
87Z-ya's Avatar
You could buy the lakewood bellhousing for our cars. It fits both flywheels. Thats what I use to hold my tremec in place. Works good.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
LT1Formula
Oct 8, 2015 08:34 PM
monte87cortez
Sep 26, 2015 08:10 PM
