5.0 LB9 TPI to 5.7 TPI swap
Old Jan 14, 2001 | 06:41 AM
88transam5.0's Avatar
I have the LB9 5.0 tpi and I'm ready to replace engine. Which 5.7 is compatiable with the tpi setup I already have, I'm looking to buy one of the GM engines but I've see a couple of different 5.7L being listed. I understand the L98 were discontinued, so which one will work for me. thanks
Old Jan 15, 2001 | 01:11 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
zz4 or anything else listed as 87 and newer, the head to intake bolt pattern is what you have to look at.
Old Jan 17, 2001 | 11:16 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
Will the TPI type heads work on the ZZ4 then? What other blocks are compatible with the heads? I know anything 87+ and non LT1 or LS1, but I would like to know specifics if at all possible.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
