fuel problem
Old Jan 21, 2001 | 11:08 PM
bill_88FB's Avatar
fuel problem
I currently have an 88 firebrid with 2.8 with fuel ingection and i fried that motor so now im dropping a 305 out of an 84 olds delta 88 with a 4 bbl and a mechanical fuel pump on the block. the 2.8 has 2 lines (fuel in, and fuel out), but the mecanical pump only has fuel in. what do i do im stumped
bill
Old Jan 22, 2001 | 10:22 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the fuel out is a return line that isnt needed on a carbed application. just block it witha bolt or something and you should be fine
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
