whats involved in making a 383 out of a TPI L98?
Old Jan 28, 2001 | 11:20 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
My GTA is getting a little tired. Id love to go 383, but whats involved? I believe id have to put a 400 crank in my L98 block, is this right? Does my motor have 5.7" rods right now? Also, what about the injectors, and throttle body? will an AFPR work with a bigger TB? One more thing, will the performance gains be worth the work and money? how much of a difference will it make? Please guys, answer all the questions you can. THX
1989 GTA, L98/auto, t-tops, Black w/ grey int.
Ran a 14.85 @ 93.4 mph w/ 305 exhaust (2 little crossflow mufflers), descreened MAF, TB coolant bypass, and casting wall ground down behind throttle plates.
Old Jan 29, 2001 | 12:09 AM
transampwr's Avatar
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
From what I've heard a 383 can make at least 400 hp. I'll say it's worth it, if you do it right. I'm planning on having Lingenfelter Performance build me a 383 stroker and turn my docile '87 T/A into a Mustang killer. My advice is to have someone who knows what they are doing and MUCHO DENERO!! (lots of money)
It's all fun and games 'till someone looses an eye....then it's fun you can't see!!
1987 Pontiac Trans Am
-305 cid motor
-700-R4 Transmission
-K&N Air Filter
-Flowmaster 40 series
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-180 degree Thermostat
-2.73 Posi Rear End
-JVC Head Unit w/ Kicker subs!
-And a COOL LOOKING Flowmaster sticker on the dash!
WOO-HOO!!
*Long live the F-Body!*
Old Jan 29, 2001 | 11:13 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
To convert your 350 to a 383, you're correct, you need a 400 crank. You can keep the 5.7" rods but you should look at getting special stroker pistons. Another thing you need is an external damper and a 400 flywheel (not sure on the flywheel). Check the archives, there are tons of posts. I would recommend a stroker kit. Scoggin' Dickey has a great kit and Powerhouse has an inexpensive, but good kit. I don't know about the AFPR, but it should work.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
