305to350swap
305to350swap
Hi iam from Australia we have a 89 rs camaro i hae just finished 350 swap the motor came from a canada truck 4x4 we think a 93 mod the motor had no air inj fitted to it from factory so i have used the a/c bracket from the truck which has no air pump bracket fitted it makes the a/c site higher and closer to the water pump but the hood still closes just makes motor much cleaner to look at .I have a few problems the car seems to have a slight surge when driving and will sometimes run rough but will clear it self i hav ordered a 90 caprice lo5 chip which i should get in a week or two $52 us i hope this will fix it .But my biggest problem is my auto before swap at wot the car would not change from 2 /3 but driving normal it would.During swap i have fitted new governor and a corvette servo the car already had a b&m shift kit fitted i still have the same problem also it wont go into o/d below 60 mph i have adjusted tv cable . Any ideas
If you are using the LO5 chip find out what injectors it's for, the L05 came with 65# and 55# injectors.
Can't help on the tranny.
And you consider the use of punctuation, not flaming you, but that post is VERY hard to read.
