350, 396, or 454 in t-tops car.
Hey I just bought an '87 Firebird and its got a v6. I want to end up putting a 350, 396, or a 454 in it. But I've been told that since its a t-tops car that the torque could twist the frame. Would I have to put a roll cage in the car or are there easier ways to reinforce the frame?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 350, 396, or 454 in t-tops car.
A good solid set of sub fram connectors will help enough for a nice 350 or a mild 396/454. A radical big block might need a 6 point roll bar to help things out a bit. Other than that, shouldnt be a big deal.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
In my opinion, subframe connectors should be the first modification done to any 3rd gen f-body. My Berlinetta #1 was a V6 car, non-T-top, and it had cracks in the roof at the door corner. These cars just aren't stiff enough, but sub-frame connectors do wonders.
Okay, now that i have found subframe connectors on summit racing, which is better; bolt on or weld on? Which has a better chance at being more durable and could be stronger? And which of the connectors on the following links are the best? Or do you know of better ones?
BOLT ON:
http://www.summitracing.com/search/D...C/?Ns=Rank|Asc
WELD ON:
BOLT ON:
WELD ON:
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I put SFC in my car within the first week I owned it. I now have a full cage and still have T-tops.
Weld in SFC are better. Many people buy the bolt in ones then get them welded later. Because of the amount of body flex, bolt in only will eventually loosen or elongate the mount holes.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
http://www.summitracing.com/parts/CEE-3046/
That is the cheap ones i have, they do great, i would tell the difference right away.
The support the LCA very well.
