LT1???to 92 RS??
Car: `86 SS / `87 SS
Use the search feature. I found posts from Texas LT1 (I think) that had info on the A/C clearance (not the frame on a 3rd gen)
Friend just got done with a 95 LT1 / 4L60-E into a g-body. Includes working SES light & VATS. The wiring seems a lot less than I originally thought (plan the same sway myself)
I don't know how you'll be able to use the pulse from the transmission with your speedo; the pulses are different to the best of my knowledge.
The trans. should have the same tailhousing as any third gen 700-R4 so that'll work, as will the driveshaft. I would keep the stock alum. 92 radiator, and run the heater line from the H2O pump from the pump to the old heater-core - to - PS tank of the rad - port.
The small coolant line that goes to the DS rad. tank in a 4th gen F can be capped off; the Vette does not use it.
The upper and lower radiator hoses are guesswork; try an upper from a 4bbl 3rd gen trimmed; the lower, you *might* be able to use a 307 g-body upper for that.
As you can see, I take notes when my friend does this ch¡t
; Plan on the same swap myself, but with T56 into 86 Monte, which is already hydraulic T5'd....
jmd
L69 / T5
; Plan on the same swap myself, but with T56 into 86 Monte, which is already hydraulic T5'd....------------------
jmd
L69 / T5
Car: '85 Z28
Engine: 396ci LT1
Axle/Gears: 4th Gen rear with 4.10s/Eaton posi
The wiring is the most difficult part...by far! Take a look at the site in my sig, for a brief overview of what I did to get my swap accomplished.
It's not the only to do it, but it's instead how I did it. Good luck and have fun!
Eric
Red T-Top '85 Z: LT1/A4 (Inoperable and waiting to undergo surgery)
-Pics of LT1 swap and brief install guide: Guide/Pics, Pics, More Pics.
Red Hardtop '85 Z: LB9/A4 (Awaiting transplant of LT1/T56 combo)
Moderator @ www.mnfbody.com
Eric
88SS6SPEED
Nov 11, 2015 07:05 AM
