I doing a v8 swap need help
Old Feb 14, 2001 | 07:03 PM
82camarov6's Avatar
I am doing a v8 swap in to my 82 camaro v6 car I have the motor in tranny and running
I need help!!!
#1 The exhaust what size sood I have on my
car and can you put dual on a 82 camaro
#2 were is the coolant temperture sensor at
on a 82 305
#3 which fan is bader a felex-a-lite fan or a electric fan
#4 I have a TH 400 tranny in my car is the TH 400 a good Tranny to have
THANKS
PS post photo of your exhaust and motor if you have any
C man
motor was a 2.8L v6 now it is
a 305 H.O. with
heads and cam, intake
manifold and crak are out of a 400 motor a th400 trany.
chrisblaster.homestead.com
my car pagewwwhomesteadcomcman.homestead.com/car.html
Old Feb 14, 2001 | 08:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
1. Exhaust- run a single 3" true duals run too close to the ground.
2. Coolant temp sensor i'm not sure of. Collant temp sender (4 guage) is in the front by the gooseneck
3. The flex-a-lite is an electric fan...
4. The th400 trans is the strongest GM automatic (I think. Maybe a powerglide {Talking stock}) it also has the highest amount of parisitic hp loss and isn't nessesary behind a 305 or 350 for that matter, but if you have it, use it (X-member and driveshaft mods)
Good luck with your swap!
Old Feb 15, 2001 | 09:45 AM
82camarov6's Avatar
THANKS FOR the info joelol75
the coolant temp sensor is working thanks TO you.
Todays ? is:
can you use the v6 P.S. pump on a 305
if you swap the pulley and bracket off the pump,
I have a v8 p.s. pump off a camaro but
it does not work,
and how do you get the p.s. pump pulley off
C man
a 305 H.O. with
[This message has been edited by 82camarov6 (edited February 15, 2001).]
Old Feb 15, 2001 | 04:28 PM
MikeS's Avatar
I suppose you could reuse the V6 pump if you put it on the V8 pulley and brackets. At the time I didn't know how to do that so I just grabbed a V8 power steering pump from a junkyard with all of the brackets still attached. But to answer your question, the power steering pump pulley is press fit onto the shaft. You'll need a special puller tool to get it off. They sell them at most auto parts stores. It is basically two pieces that clamp onto the hub of the pulley (there is a little groove where it grabs on...you should be able to find it if you are looking at the pulley). Then you basically tighten a special bolt down that will cause the tool to pull the pulley off. I had to do this after my pump decided to come loose from the brackets and the pulley was in the way of getting the bolts back in. Good luck
Old Feb 15, 2001 | 04:42 PM
82camarov6's Avatar
thanks
that is what i was thinking how you got I off.
I have some puller at my house
V8's RULE
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
