92 3.1 to tpi help
Old Oct 17, 2009 | 12:49 PM
miller_stunts's Avatar
92 3.1 to tpi help
has anyone done it? can i use my wiring?
Old Oct 18, 2009 | 06:34 PM
Re: 92 3.1 to tpi help
anyone?
Old Oct 18, 2009 | 09:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Are you wanting to put an 8 cylinder motor with a TPI induction setup in, or are you wanting to use a TPI setup on your 6banger?
Old Oct 18, 2009 | 11:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think he's wanting to drop in a TPI engine & reuse as much wiring as possible (ecm if possible).
The best asnwer is to lok up/print out the wiring schematics & compare the 3.1 to the TPI.
It's not that hard, as I did it for a 85 2.8 into a 95 3800II (including dash w/87 cluster swap & integrate 85, 87, & 95 wiring.... such fun it was)
Old Oct 19, 2009 | 06:46 AM
thanks i will start there
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
