Stock v6 pump work with 8?
Old Feb 18, 2001 | 10:02 AM
Lov2xlr8's Avatar
I am doing a swap to a GM goodwrench replacment 350. Will my stock pump work if I put TPI on this beast?
Old Feb 18, 2001 | 06:22 PM
BTS88IROC's Avatar
I believe you will need to switch to a larger pump or you may be starving the engine for fuel. You could just get an inline one or maybe just snag a v-8 camaro/firebird one from a junkyard. Although they are in the tank which would be a pain.
Old Feb 22, 2001 | 06:06 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
When i went from the multi port 2.8 to a tpi 305 i didn't change the pump. It worked fine in my case. It didn't run lean or anything.
'88 RS (originally 2.8)
New 350, .040 over, ported vette L98s, ported stock tpi.
Old 305 injectors & chip
TES headers, 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
(Damn the 2.8!)
Old Feb 22, 2001 | 06:24 PM
442guy's Avatar
rob you puts you dont have to change it. as long as the fuel pressure is 43.5 psi at idle, and 55? at full? well, as long as it goes up when you hit it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
Briandrex
Oct 5, 2015 06:20 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
