what parts needed to get a 350 to rev to 5500-6000
I have a 91' Z28 305 TPI now, I want to put in a stock L98 (350), with a cam that would increase my redline to 5500-6000. Now I know that stock parts are barely good enough for my current redline. What parts will be needed to make this cam do more good than evil for the car? Do the heads flow well enough, would a port and polish get the job done if not? Also how about the ignition system, is it able to fire effectivly in that range? I want to make a cost effective 350 TPI that'll take me into the 13's for now. Is there a beter way for this than what I'm doing?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're beating a dead horse. No matter what parts you change the one thing that's holding it back is the intake. A factory TPI is useless above 5000 rpm.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 91 Red Sled
Swap to TBI
, j/k
It is an option though, the short runners help with the high rpm. It's either that or spend $$$$ for an aftermarket TPI system. Then there is always the carb if you don't mind the 8mpg.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
, j/kIt is an option though, the short runners help with the high rpm. It's either that or spend $$$$ for an aftermarket TPI system. Then there is always the carb if you don't mind the 8mpg.
Errr....damn...then what should I do. Want to get into the 13's by this summer and without a bottle to help. What should I do? Now i can't build the 350 because I have no place to do it, so any swap would have to be done by a shop. Would it be better to just stay 305 and build it up?
theshackle
Sep 17, 2020 08:26 AM
