Need 383 stroker and S.B. info.
Old Feb 27, 2001 | 12:53 PM
Jack's Avatar
We are currently looking for a 4- bolt main block to build up a 383 stroker. Have located a 4-bolt main, one-piece rear seal block but am running into an issue that we need help with. That being the difference between a one-piece rear seal block vs. a split seal block. Have not yet come across a stroker kit for the one-piece seal block. Do they exist? If so who? We are also being told by a local speed shop that the machine work required on the one-piece seal block to prep it for the stroker kit is more extensive than that required on a split seal block. Is this true? If so, why?
90 Trans Am GTA
5.0 TPI
5 Speed
T-Tops
Old Feb 27, 2001 | 01:18 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I believe Powerhouse has a 1-piece kit, otherwise you can just order the parts seperately. SCAT makes a one piece rear main seal stroker crank. As far as the machine work....I don't see why it would be more money.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
