400 block
Old Mar 2, 2001 | 02:23 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
400 block
Will the 400 block fit in my formula with no problems. there is a 305 in it. what would be the best rods, and pistons to get for the 400 block. this is what i am thinking of doing:
400 block w/splayed main caps
bore it to .030 in over
stroke it 3.75
What else do yall think i should do.
Old Mar 2, 2001 | 02:59 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
<font face="Verdana, Arial" size="2">Originally posted by 92formula:
Will the 400 block fit in my formula with no problems. there is a 305 in it.</font>
Yes
<font face="Verdana, Arial" size="2">...this is what i am thinking of doing:
stroke it 3.75
</font>
Good call on the splayed conversion, use a 2 bolt block. Cheap insurance. If it's doesn't need bored, I wouldn't. It's your lucky day, you ALREADY have 3.75" of stroke.
<font face="Verdana, Arial" size="2">What else do yall think i should
do.
</font>
Buy 1 3/4 headers, buy good heads and upgrade to a bigger radiator.
[This message has been edited by 96BlownSSragtop (edited March 02, 2001).]
Old Mar 2, 2001 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll need to either internally balance it ($'s), or get an external balance flexplate and damper. The 400 flexplates all seem to be 14". Starter mounts have also been discussed as a problem area here - the word seems to be to get the block drilled & tapped for straight-across starter mounting bolts.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
anesthes
Sep 18, 2015 12:34 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
