ZZ4 conversion kit
Old Feb 26, 2001 | 10:34 AM
BairsZ28's Avatar
ZZ4 conversion kit
I plan on doing this swap in the next month or so and was wondering if anybody has any experience with this swap and what they have done? I plan on putting some SLP headers on instead of the maniflods it comes with, and then later porting and polishing the heads with bigger valves. Any comments would be appreciated, thanks.
Old Feb 26, 2001 | 02:27 PM
89V6toV8's Avatar
What is your question refering to?
Old Feb 26, 2001 | 09:32 PM
BairsZ28's Avatar
What I would like to know is what kind of problems did anybody run into while doing the swap and what modifications they have done?
Old Mar 5, 2001 | 05:57 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Couple of things. The stock ZZ4 valve covers do not have the grommets in the proper place for a TPI set up. If you have an engine oil cooler, the lines will not pass between the larger ZZ4 balancer and the oil pan like on the L98 350.
You will also need a new water pump for a serpentine set up. The passenger side head was missing one bolt hole for the serpentine bracket (1992 model with A/C on the pass side) However there are plenty other mounting points to keep things tight. Check your SLP headers for squareness on the flanges. My 4/6 flange is a little off.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited March 05, 2001).]
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
LittleFranks
Oct 7, 2015 11:26 PM
Magman
Sep 13, 2015 12:14 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
