help, 305 to 350 swap in progress
Old Oct 25, 2009 | 07:22 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Hey everyone,
swapping a 305 from a 86 tpi to a new 350. I was told this was a tpi engine that was converted to carb and I seen pictures before I bought it. The mechanical fuel pump on the original 305 cant bolt over to the 350 block, there's no spot for it. I am thinking there is a electtric pump in the tank that must have been run to the carb direct. Can anyone tell if there is a pump in the gas tank?
Old Oct 25, 2009 | 07:52 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: help, 305 to 350 swap in progress
Let me see if Im reading this right. You want to use the mech fuel pump that is now being used for the 305. for a new 350 without fuel pump mounting spot. But you cant, so you want to try and use elec pump in tank if there is one.Do you want to use tpi ? If so the pressure is different from carb.
Old Oct 25, 2009 | 11:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You must have a carb in your car, and the new 350 was a TPI motor, so it doesn't have the spot for the mechanical fuel pump on the driver side block, right? But you are sticking with your carb, and just need to get gas to it since the mechanical fuel pump won't bolt on the new block, right?
If this is the case, then I would think that you could add any inline elctric fuel pump to your system, since you are carb originally you just have a carb pickup in your tank (I assume), and thus any electric pump making 5-7psi will work inline. As I understand it, you'll want to mount it as close to the gas tank as possible, as they can be noisy, and they perform better being closer to the tank (not having to pump from so far away). But get a second opinion on this.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
