overnight question
Old Mar 11, 2001 | 06:28 PM
86rubyredLG4's Avatar
overnight question
1. What do i have to loosen up if i want to take out my 86Lg4 bird engine from the transmission?
2. How do i lift the engine are there attatching points or do i have to put bands around it ?
thnx
Old Mar 11, 2001 | 09:38 PM
chevcam1's Avatar
hey im new to the board but i need to say that if you need to ask,you shouldnt try to do it alone!find a friend that has done it before and bribe them to help.theres a lot more involved than pullin a few things here and there.plus theres the danger factor.dont try it alone.i never pull a motor by myself.ill always have someone to spot me and ive been pullin motors 15 yrs. its just good shop safety.ill never tell someone not to work on their own ride its fun and you take pride in it when its done knowin YOU did it!!get in and get greasy but get someone that has experience to assist/guide you.
HAVE FUN!!!
Old Mar 12, 2001 | 12:45 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I would write down step by step but I am sure I’ll probably leave something out. It is better to buy a Chilton’s or equivalent manual. The manual will list the steps for you. As chevcam1 had stated, DO NOT TRY IT ALONE.
[This message has been edited by 86z/92rs (edited March 11, 2001).]
Old Mar 12, 2001 | 02:07 AM
I kinda now what im doing and im not doing it alone i got everything loose already it was just a small question i wanted to know for sure cause the chilton is not to clear about these two things. LOL, try to find someone with experience on this side of the world the only firebird seen ever in this region was the knightrider. Im a proffesional aircraft mechanic and swaped lots a turbine engines already so i think i can manage. So if anyone can stil help me out there?
Old Mar 12, 2001 | 12:19 PM
86z/92rs's Avatar
Their are some bolts on the back of the heads which hold the wire looms, air tube to the catalytic converter and etc. It is hard to remove those bolts with the motor in place. I would suggest that you pull the motor out slowly and try to undo do the bolts when you get enough room to get a socket in place. As far as lifting the motor out, you can connect the fittings that came with chain to your manifold bolts. Best way to do it is on the passenger’s side use the manifold bolt closes to the front of the motor. On the diver side, use the manifold bolts closes to the firewall (rear) of the motor.
Hope this helps, anymore questions, just ask.
Old Mar 12, 2001 | 06:11 PM
chevcam1's Avatar
sorry i didnt mean to sound like a jerk. just wanted to make sure you keep all your limbs!if you can change an aircraft eng you shouldnt have any probs. i wouldnt dream of diving in there. but i can cut a car in 1/2, put it back together, make it go down the road straight and not worry about it comin apart!anyone thats pulled a motor can help, fbody experience is not mandatory just automotive in general.
like i said before have fun
Old Mar 13, 2001 | 06:09 PM
I bow to all you pro`s
im greatfull to you all
o yeah i got the engine out and now pulling the one out of my donor car. There are probably more q`s comming cause not everything is the same
I thank you all
this messageboard is the best way to ship experience to europe
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
