350 build
Old Nov 5, 2009 | 08:43 AM
camaro2.8's Avatar
350 build
i am building a 350 for my 87 camaro and i have a mid 70's 350. are the mounts all the same as the 87 V8?
Old Nov 7, 2009 | 11:21 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
Re: 350 build
yes pretty much every 350 block from the 60s to early 90s had same mount paterns i put a 350 from a 1967 truck into my 1987 camaro
Old Nov 8, 2009 | 12:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the record, trucks didn't get 350's until the 1968 model year.
But, basically, the mounts/bellhousings were all the same.
Old Nov 8, 2009 | 07:22 PM
sinkorskin's Avatar
Re: 350 build
Hi i have a 91 rs 305 5 speed. I am supposed to get a 1969 bone stock 350 complete minus carb for free. I am in CA so im worried about the block have provisions for smog pump. Anyone? I am also worried ill fry the tranny. The engine runs but the man (my 70 year old hotrodder neughbor) said it has a bita smoke in the morning piston rings im guessing but he says it ***** and gits after warmed up. I am going to go 30 over with hyper pistons trick flow smog legel heads smog cam headers edelbrock tbi intake turbo city tbi and get a 350 tbi ecu and custom chip. Im guessing power output at around 300-350. Will my tranny handle this? is there any other things i should know? this car will see the track but not a straight one. ps its a convertable. Will i have problems with twisting the unibody frame from this amount of power? oh and power estimate is at the fly no wheels. THANKS!
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
