350 build
Old Nov 5, 2009 | 08:45 AM
camaro2.8's Avatar
350 build
i am building a new 350 for my 87 camaro and i have a mid 70's 350 will it work?
Old Nov 5, 2009 | 11:48 AM
camaro2.8's Avatar
Re: 350 build
i wasnt sure if all te mounts were the same or if i would need to get a newer motor
Old Nov 6, 2009 | 04:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Differences (assuming it's a complete mid-70's engine):
Intake manifold mount bolts - the center two on each side on the '87 are at 72 degrees, whereas the older engine has all of the mount bolts at 90 degrees.
Rear main seal - the '87 is one-piece, and the older engine is 2-piece. The flexplate/flywheel is different between the two types.
Dip stick location - on the older engine, it's on the driver side, and gets in the way of the exhaust manifold. If you use headers, no problem.
Valve covers - the '87 heads use center bolts, the older engine uses perimeter bolts.
Oil galley ports - the '87 may use a port above the oil filter that the older engine doesn't have.
Externally, other than the above, the engines are identical.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
