I need you advice and opinions
Old Nov 7, 2009 | 09:53 AM
Red Baron 361's Avatar
Car: 1987 Camaro z28
Engine: 350 bored 40 over carbed
Transmission: 700r4 with B&M hard shift kit
Axle/Gears: posi
Whats better a sbc 400 or a sbc 350 i wanna kno which one i should put in my car i have both the motors
Old Nov 7, 2009 | 10:49 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: I need you advice and opinions
A 400 is ok for about 500 HP, i have seen them go further, way more than that, but that is safer in the 550 HP range. More cubes, more better. BUT, the 350 1 piece rear mane seal can be bores and stroker to 396 or more cubic inches. I like the 1 piece rear mane seal blocks better. They can take TONS of abuse and i have seen them go .080 over bore several times. Not to mention, if you crack a 350 block, there is another one laying around somewhere and you can just swap the parts.
You crack a 400 block, you have to go out of your way to find another one and i have friends that have gone thru 3 blocks before finding one that wasnt junk.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Jlanz55
Sep 29, 2015 08:55 AM
