Cams
Car: 1986 Camaro Z28
Engine: 305 Carb
Cams
It has been a while since I have done a SBC and I am trying to decide what cam to go with. The engine is a LB9 TPI 350. I plan on going to a carb setup with a Edelbrock Performer intake ,600 CFM carb and headers. rear is the stock 2.73 was planning on going to 3.73 and maybe 2800 or so stall(to come at a later time). I think I am going to leave the bottom end stock as well as the heads. Just want a solid running car. Any idea will be useful. Thanks..
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Cams
Well, if you have the flat tappet motor, which in 86 was a 1 piece rear main seal but non roller, then it will be cheaper to go with a flat tappet cam, but if for whatever reason you have a OE roller, here is a cam for you, priced right and runs its tail off with a mild engine combo(i have one):
http://competitionproducts.com/prodi...p?number=E1135
That is a great cam for the heads you have. If not, there are some great flat tappet cams ground close to those specs. It will suck till you get a 2500 stall, but it will still go and will bennifit TONS with the 3.73 gears.
Engine: 305 Carb
Re: Cams
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Cams
'91 would be a roller cam engine... but is it a 305 or 350? The LB9 designation is for the 5.0 TPI...
Engine: 305 Carb
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Cams
Yep, that cam i recommended will go right in and re use the original lifters
Engine: 305 Carb
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Cams
You will need the machine shop to spec the heads for you. The stock springs probably wont cut it. But a set of LT1 springs, locks and retainers will probably do the job.
Transmission: 4L80E/4L80E
Yes, but the cam has too much lift for the heads. The valve retainers will hit the top of the valve stem guides, and the only way to fix that is to pull the heads and have the top of the guides cut down. You can do it yourself if you buy the right cutter, but a machine shop should be able to do it quickly. If you ask them to install positive-type stem seals which require cutting the top of the guide, this takes care of the issue and gives you a better type of seal.
Engine: 305 Carb
Re: Cams
Just for info sake does anybody know the specs of a LT1 hot cam?
Damn I am still very undecided about a cam!!!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Cams
That is with 1.6 rockers. It is .492 lift with the 1.5 rockers.
Engine: 305 Carb
Re: Cams
I do like the price of the cam you mentioned but what will I need to put with it to make it work right? On that page all I saw was the cam.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Cams
Like i said, a set of springs, locks and retainers should be all you need, a machine shop should be able to get you a set of LT1 springs and locks/retainers for cheap. Ebays will even have some cheap ones like i have on my 86 TA with the same cam. I went over kill since i wanted springs that are good for 550 lift. I have 1.6 rockers on the exhaust side.
Re: Cams
Correct. And, it's the LT4 Hot Cam. There was no LT1 Hot Cam.
https://www.thirdgen.org/mods3 Toward the bottom of the page under "GM High-Performance Cams".
