L98 Build list
Old Nov 9, 2009 | 11:33 AM
TJ07RK's Avatar
Car: 1986 Camaro Z28
Engine: 305 Carb
L98 Build list
Ok I think I have put a list of stuff together, wanted to see what you guys think, so here we go. All of this list is from Competion Products. The engine is a 91 L98 TPI 350 that I am going to convert to carb.
Cam = Chev 305-350 ('87-'94 w/OE roller lifters)
Duration @ .050": 230/230
Adv. Duration: 306/306
Lift: .480/.480
Lobe Center: 108
2500-5800, Moderate idle, Street/Strip
Lifters = Chev SB, OE Roller Blks
Springs = O.D.: 1.265
I.D.: .875
Style: Single w/Damp
Seat Pressure: 115 @ 1.750
Open Pressure: 340 @ 1.250
Rate: 425
Coil Bind: 1.150
Max Lift: .550
Retainer: 97112, 97132, 97214
Rockers = Chev SB (87-Up), 3/8" 1.5, Self Aligning
Push Rods = 5/16", 7.195"
Intake = Professional Products, CrossWind Dual Plane Intake, Chev SB
Headers = Hooker Headers 2055-1HKR
Stall = 2800 (not from Comp Products)
Old Nov 10, 2009 | 11:51 AM
TJ07RK's Avatar
Engine: 305 Carb
Re: L98 Build list
Good...No Good.. Just looking for opinions!
Old Nov 10, 2009 | 05:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds decent.
Are you planning on doing anything with the heads other than the valve springs?
Old Nov 11, 2009 | 08:54 AM
TJ07RK's Avatar
Engine: 305 Carb
Re: L98 Build list
Originally Posted by five7kid
Sounds decent.
I think so, but not sure what yet.
Old Nov 11, 2009 | 03:31 PM
five7kid's Avatar
In another thread I suggested having the top of the valve guides cut for positive type stem seals and port/bowl clean-up. That's a good start.
Pinning the rocker studs or having screw-in studs installed wouldn't be a bad idea, either.
Old Nov 11, 2009 | 03:48 PM
TJ07RK's Avatar
Engine: 305 Carb
Re: L98 Build list
I have been talking to the guy that did a lot of LS1 work for me. I am going to just take the heads to him and figure out what they need from there. I was thinking since they will be out there anyways might as well do it right.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
Gunsbee
Sep 7, 2015 07:10 PM
greenyone
Sep 2, 2015 03:39 PM
