tpi fuel pump v.s. tbi fuel pump.
Old Apr 13, 2001 | 11:38 AM
442guy's Avatar
can i use a throttle body injectio fuel pump with tuned port? the displacement of the motor is the same? will it pump insufficient pressure?
Old Apr 13, 2001 | 11:43 AM
Mach5's Avatar
No you can't use the TBI pump with the TPI motor because it provides less pressure than the TPI requires. It runs around 40psi at idle whereas the Tbi runs around 13 or soemthing like that. Hope this is of help to you
Old Apr 13, 2001 | 04:58 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
no you can't use the TBI pump with a TPI
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
