Help! Cant get it back together!
Old Apr 13, 2001 | 07:38 PM
Brian Decker's Avatar
I have a 85 Camaro Z28 I cleared out the engine comapartment over a year ago. I found another engine but, now that I that I have it in the car I cant remember where everything goes. Yes I know I should have labeled. I was very distraut at the time and wasn't thinking. I don't know anyone in the area with a Z to compare with. Thanks for any help in advance.
[This message has been edited by Brian Decker (edited April 13, 2001).]
Old Apr 14, 2001 | 01:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Man, that's not good. I don't tend to label as I disassemble on my '57, and haven't on several other "older" vehicles I've worked on in the past couple of decades. But, I can assure you, I labeled EVERYTHING I took apart on both the donor and driver cars when I did my swap.
You can sort of trace out your vacuum lines based on the decal under the hood, assuming it's still there. You might be able to figure out wiring by tracing down the schematic in a Haynes manual (it's actually pretty good for an '85 model). But, your situation is exactly why it's recommended to take pictures before anything is taken apart, and to label things as you disassemble.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Old Apr 14, 2001 | 02:08 AM
TriGenRS's Avatar
Are you talking about the lines or the lines AND parts??
For your lines.. I'm guessing you didn't totally take off the lines from the part. There is at least a part on one side of the line isn't there?? If you describe the part the line is connected to and the size of the line, maybe some of the people here can help you out. (ex: there's a skinny rubber tube connected to an elbow on the intake-behind TBI). If you TOTALLY took off the lines off everything it will be alot harder to re-trace. But your best AND fastest bet would be on comparing it to a friends car you can see.
89CamaroRS
Power Rating: 1.21 Jigowatts
Mods:Flux Capacitor
Future Plans: Time Travel
Old Apr 14, 2001 | 10:36 AM
five7kid's Avatar
Go to the Owners List https://www.thirdgen.org/newdesign/owners/view.html and do a search. You just might find someone closer than you think who would be willing to bring their car over and help you out.
Fronzizzle
Mar 18, 2019 08:29 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
db057
Aug 22, 2015 08:17 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
