Going shopping for a junkyard 350 for my 86 TPI. What do I look for?
Old Apr 17, 2001 | 07:59 AM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
OK Guys I decided I am going to build a 350 to replace my old worn out 305. I would like to know what should I be looking for. Truck engine, car engine? Make model year or casting numbers. Basically i am just looking for a 350 motor that will drop right in place of the 305 and hook up to the 86 TPI intake and stuff. Please help I need to do this quick.
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Apr 17, 2001 | 09:48 PM
buddha6974's Avatar
At the very least, pull off the heads and oil pan in the junkyard. look for fragged pistons and bottom end. Also try to turn the engine over with a big breaker bar before disassembling it, if it turns over, chances are it is good. as far as the efi stuff, it is my understanding you can put that on any small block, i could be wrong.
i only give the advice about pulling the motor apart because it happened to my when i was young and stupid.
dan
i got an 84 camaro, shes got a 89 mustang. which do i have to work on more?
Old Apr 18, 2001 | 08:10 AM
82suped-up-coupe's Avatar
if you just wanna drop it in get a car motor
if you are willing to do a cam swap get a truck or van motor because they are more likely to have 4bolt mains
ya take the pan off if they'll let you and most definately check the compression
as far as I know the EFI should bolt up no prob
If you can't take off the pan or do a compression check pick one from a car that looks stock(no big ram air hood scoops and such), and has clean oil.
you don't want to buy a motor that has been run to death I'm guessing
good luck and have fun
I just did the same hunt and just finished building a 320hp 355 for a total cost of $400 canadian(the fact that I work at a high performance shop does help cut costs)
Rich
Old Apr 18, 2001 | 09:39 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
they changed the center intake screw angle somewhere around 86, also went to one piece rear seal
Old Apr 18, 2001 | 11:14 PM
Russ-So Cal's Avatar
Stay away from four bolt mains. GFM did it wrong. If you want four bolt mains, get a two bolt, and have a machine shop drill it for splayed four bolt mains.
Old Apr 19, 2001 | 01:45 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
look for something with 8-cylinders.
j/k
ask the place. around here they have motors they knew were good and already removed them. I hope you are going to rebuild it right? It is hard to check a block without it being on a stand. At least check the lifter valley and make sure there is no cracks there.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 22, 2001 | 08:01 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Never mind.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited April 22, 2001).]
BlueIroc-Z
Jun 9, 2019 03:22 AM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
st.evel07
Aug 13, 2015 06:15 PM
matthew911
Aug 12, 2015 09:38 AM
