305tpi to350 tpi
Old Apr 24, 2001 | 08:04 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
305tpi to350 tpi
Decided to forget about building up the 305. The car is a 85 Trans am w/305tpi. I have found several 350 chevy small blocks in my local paper. What kind of years should I be looking for and out of what? Will I be able to bolt the tpi setup onto the block? What else needs to be changed? Price range for all of this to be installed?
85 305tpi Trans am
flowmaster exaust
K&N air filter, 4:11 rear gears
Old Apr 25, 2001 | 09:27 AM
MAXGTA2002's Avatar
Hey there,I'm in the same boat you need to check your bolt pattern, whether or not its a center bolt head, all 350 will go in,it's the hardware,like; valve covers, intake bolts and sending units, pully hardware brackets. Where is your A/C? I don't know about 85 t/a's whether or not they were roller engines? Hope I can help a little!
DON
[This message has been edited by MAXGTA2002 (edited April 25, 2001).]
Old Apr 25, 2001 | 05:45 PM
rdog30's Avatar
Car: 85&95 Trans am
It's not a roller engine that I have now. A/C is on the driver side,Alt. on pass. side. I don't have center bolt valve covers. What kind of 350 should I look for?
85 305tpi Trans am
flowmaster exaust
Old Apr 26, 2001 | 09:56 AM
MAXGTA2002's Avatar
OK, are you going to use the existing valve covers you have now? you can use any 350 that you can install all of the sending units, I would use any from 86 and higher that is not a center bolt if your going to use your old stuff or you get a complete motor with all the hardware whether it's a roller or not, now the tricky part is finding a computer that is compatable with your aplication, changing from 305tpi to 350tpi, that's what I run into now, to use your existing wireharness you need to have the same wire set up, computer, for example if its maf 305 now, you need a maf 350 computer. some say just change the prom,chip.
I'm still checking, Hope this will help some.
Don
[This message has been edited by MAXGTA2002 (edited April 26, 2001).]
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
