Need procedures TBI to TPI
Old Nov 17, 2009 | 08:49 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
Need info on how to convert my TBI into TPI. I got the MAF TPI setup does anybody have the procedure on how to do the convertion? I already have the TBI setup completly off with the wiring harness just need procedures on how to slap on the TPI, any info will be greatful
Old Nov 18, 2009 | 12:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure what you mean by "procedures".
If you mean things like torque values, a Haynes manual will give you all that.
Otherwise, it's a matter of bolting it on, running the hoses and cables, routing the harness, etc.
Did you get a TPI in-tank electric fuel pump?
Old Nov 18, 2009 | 11:55 AM
Car: IROC
Engine: 383
Axle/Gears: 3.45
Re: Need procedures TBI to TPI
I beleive the last Time my fuel pump went bad I installed a ss pump in it but not to sure, but I should be able to pressure test it with the guage.
Old Dec 30, 2009 | 08:39 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
nobody has any info?
Old Dec 31, 2009 | 10:18 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Few tings to consider.....
TBI and TPI fuel pumps are completely different and NOT interchangeable. They run at different PSI.
TBI cams are smaller than TPI ones.
TPI computers are different fromTBI.
I believe the wiring harnesses are different as well.
Might consider an AFPR (holley). Setting the AFPR will give you a few more HP.
I bougt a complete TPI engine (with harness,ECM and fuel pump) to make my swap easier.
Might consider a used LT1 cam install...you can pick up a LT1 cam for about $20 or so.
Old Dec 31, 2009 | 10:45 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
I got all that, I can also install it but I just simply want procedures, step by step on how to install just so I can feel comfortable installing it
Old Jan 10, 2010 | 04:54 PM
jamieschott's Avatar
Look in the tech articles. You will find an article there on the replacement of the intake and such. In the TPI forum, you can find a sticky about repining the TBI harness to the SPEED DENSITY harness. I completed this task last spring with no issues.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
