Pinion angle???
Old Apr 27, 2001 | 08:01 PM
Camaroman's Avatar
Pinion angle???
I'm putting a ford 9" in my '84 Z28 w/ a 454....probaly a tremec tko 5 speed...
I dont have the tranny...or the motor in the car...I need to know if anyone knows what my pinion angle should be set at...from plumb.
Or for some FYI does anyone know where the crank center line sits with this swap?
Old Apr 27, 2001 | 11:18 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You don't set it from plum, you set it from the drive shaft angle relative to the rearend.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old Apr 28, 2001 | 03:54 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Around -3 degrees is a good compromise between off the line traction and long u-joint life.
It may vary some, but more than -4 is real hard on the u-joints and nowhere around zero or positive is good.
[This message has been edited by JoelOl75 (edited April 30, 2001).]
Old Apr 28, 2001 | 12:15 PM
Camaroman's Avatar
I know that the angle of it comes relative the driveshaft...but I was hoping to put the rearend in the car before the motor and tranny are ready. Therefore I dont yet have a driveshaft....
88 427 Camaro...do you know how many degrees your rear is tipped from plumb?
jbates346
Oct 21, 2015 01:50 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 17, 2015 06:58 AM
