Lowering my IROCZ
Lowering my IROCZ
I finally have the opportunity to lower my Camaro. I'm on the cusp of getting the Eibach Pro-kit which lowers the car around 1-1.5." My question is, has anybody lowered their cars this much and if so were their any problems with pinion angles or any kind of geometry. I realize an inch isn't that much but I know how sensitive these cars are. Anybody with some input please reply. Thanks again.
Re: Lowering my IROCZ
"Lowering" doesn't work like, you open the box that says "lowering" and pour it all over your car, and it just instantly jumps {fill in the blank} closer to the ground. As if, you could do that 3 times, and it would just keep getting lower.
Gotta remember, "lower" is a COMPARATIVE word. "Lower", than WHAT? well, in the case of parts f that sort, it usually means, "lower" than ORIGINAL. See this post for what your car will be "lower" than by an inch or whatever. https://www.thirdgen.org/forums/hist...od-1986-a.html
Don't be A BIT surprised if you put those springs in your car and it actually sits HIGHER than it does now.
Don't want to rain too heavy on your parade; BUTT.... ya gotta realize that that's 1 - 1½" below its ORIGINAL height, not whatever its saggy wore-out limp-{you-know-what} springs have it sitting at NOW.
...You DO Need a front end alignment. I also purchased an adjustable torque arm, but honestly I don't think it was necessary. I'll admit I didn't measure the angle with the stock arm, so I can't say for certain, but I would think you'd be ok. ......like always, do your homework and measure to be sure.
...also be sure to get good shocks and struts. They don't have to be top of the line, but don't get cheapo sears replacements. I've been incredibly happy with the Tokico HP's. Not sure if they still sell 'em though.
I realize that and I don't think its sagging that much right now......but it is starting to. I just want a little bit of drop. I just want to get rid of the annoying wheel gap! I'm going to try and get ahold of the Vogtland sales person and see if they can find the spring rates. They kinda look like progressive rate springs?
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
When I lowered my car with suspension techniques springs, the car did lower about an inch. Lowering the car also pushed my rearend slightly towards the passenger side.
I had an adjustable panhard bar to re-center it though.
Something to keep in mind.
Would you say that your ride is too firm Abubaca? Is it alot firmer than stock or just a little bit. I've always felt that my stock springs were too soft, however, I don't want to chip my teeth either.
Car: 90 Formula / T-tops
Transmission: MD8
Really good info over here. Answers your questions:
https://www.thirdgen.org/forums/susp...-before-i.html
These guys are discussing Hotchkiss springs
https://www.thirdgen.org/forums/susp...ock-strut.html
Vogtland springs over here
https://www.thirdgen.org/forums/susp...-stocking.html
Some great photos over here:
https://www.thirdgen.org/forums/susp...m-finally.html
