LT1/TH350 Flywheel question.
Old Nov 20, 2009 | 10:56 PM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
i've got a 94' lt1 im coupling with a th350. i have no flywheel. do i need a balanced or non-balanced flywheel, or does it matter?
my main concern is that the lt1 is properly balanced. ive herd people use terms like internally and externally balanced lt1's. what does this mean, and how should this effect what type of flywheel i buy. and should i be concerned about the torque converter bolt pattern lining up or is that something GM has made a universal fit.
and no im not just going to buy a t56 or aod4speed as opposed to the th350 i already have which seems to be a popular "fix" to other threads ive researched on the net about lt1/th350 setups.
thanks in advance for any help you guys have got out there, i know it can be tedious finding good information out here so it is very much appreciated.
Old Nov 20, 2009 | 11:20 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: LT1/TH350 Flywheel question.
Reason they say this is if its a one piece rear main or 2 piece. One piece when you look at where the flywheel is connected to the crankshaft. It will look like a complete circle. 2 piece looks like a T sorta. basically circle almost but 2 cut outs. On my flywheel when i removed it was external balanced by the flywheel. So i would assume if its one piece you would need the external balanced flywheel. But don't quote on this. Hope this helps. Someone chime in if i am right or not.
Old Nov 22, 2009 | 01:03 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by thedoctorisin
ive herd people use terms like internally and externally balanced lt1's. what does this mean, and how should this effect what type of flywheel i buy. and should i be concerned about the torque converter bolt pattern lining up or is that something GM has made a universal fit..
1 pce seal engines are ext balance at REAR only;neutral at front like any other SBC except 400
1 pce has a weight welded to the flexplate. Only a 1 pce flexplate will bolt to your engine; the earlier 2 pce ones have a diferent crank hub bolt pattern and no weight on them
Some aftermarket flex plates come with both common GM ( 10.75" and 11.50" ) convertor bolt patterns. See
http://www.summitracing.com/parts/BM...8/?image=large
while others one have one
http://www.summitracing.com/parts/PI...0/?image=large
Check your convertor bolt pattern 1st
( measure from bolt to center x 2 ) There was another bolt pattern GM used ( 9.75" ) but I think that was only on P/Glides
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Ian Irvine
Sep 4, 2015 08:08 AM
