at 300 HP.......>>>>>
Old Apr 30, 2001 | 08:30 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Will a 305 or a 350 get better gas mileage, in the city... Just curious....
If both engines are built to around 300 hp....
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old May 1, 2001 | 05:19 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
that completly depends on how you get the 300hp. cams, heads, ignitions, well everything will change your horsepower decreasing MPG. EFI play a big part too. at 155hp my 85 ta (305) gets roughly 19mpg. at 275hp my buddies LT1 (350) gets 19mpg. his has way more power and bigger size but the engine is built so well and since it has TPI and i have (bows shamefully) computer controlled carb, his gets the same mileage. if i tried to get 275hp out of my 305 by doin cam, heads, valves and ignition, i would probably be arround 12-13 MPG. hell my vette gets about 12 and it has 325hp.
Old May 2, 2001 | 11:06 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Hi kiztope, I noticed your working with a 3.1L V6 RS, my question is because I want to do a swap from a V6 to a V8, "What and how did you re-wire for the V8, if I'm using a donor car (1992 X-police Camaro 350) do I have to just take the engine wire harness from the computer under the dash all the way through the engine compartment and swap it with the one in the Police car. Did you have any problems with your swap to a 350?
Old May 2, 2001 | 11:25 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Havent done the swap yet, just planning it for next summer....
But to answer your question,
You do need the wiring harnass, the ecm, and just about everything else that bolts to the engine. The stuff in the 6 wont work.
Old May 2, 2001 | 11:30 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
By the way, where did you get the donor car?
Any more??
Old May 3, 2001 | 10:07 AM
Head to Houston, this town has everything, you can get them at police auctions if your REAL lucky, I'm still looking at local junk yards, don't have it yet, but a person can buy all that police stuff on the net for Camaros if you want the beefy springs and sway bars. IF you want to buy one out right, from a private seller, there is one on AutoTrader.com, the guy wants $7,500 bucks because he added some stuff.
Old May 3, 2001 | 10:09 AM
let me know how your swap goes, I want to give it a shot someday when my V6 dies, I've done Transmission pulls and motor pulls before, no big deal there but this swaping of wires can really run a person into a jam.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Royal_Z
Sep 30, 2015 08:45 PM
