rods for 383?
Old May 3, 2001 | 01:51 AM
86Z28camaro's Avatar
rods for 383?
i am building a 383 stroker from a stock 350 block and i don't know what all i need to convert it with. i know that i need new rods but i don't know what size and i don't know what other things i need to change. any help will be greatly appreciated. thanks
Old May 3, 2001 | 09:44 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
You can use your stock 350 rods, but you might be better off getting aftermarket ones. They will cause less clearance problems from what I've heard. I'm using stock rods and I hit a water jacket doing relief work on my first block!!
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old May 3, 2001 | 03:54 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
If you are going with new rods, might as well step up to the 6" rod 383 stroker kit.
It'll make more power and won't wobble the piston in the bore as much at high rpm.
Old May 4, 2001 | 03:42 AM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
I am currently building a 383 right now.
i am using 5.7" rods that I ground on the rod bolt area, and i am having the machine shop clearance the block while they do the other work.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
