Could I make my 700r4 to stand up to a ZZ4???
I am thinking of a motor swap in my 92 rs 305. Maybe a ZZ4 or something with equivalent power. I also plan on running it carbed.
Will my 700r4 (has 116,000 miles on it) be able to hold up to this? I realize it probably won't last long, but would it be possible to get it rebuilt to last for a long time?
Or should I buy a new tranny? Maybe a th350 or th400?? I sure would like to keep OD though.
Keep the 700 man when built up it is one tuff SOB but in factory dress can be kinda soft if your gona rebuild it, it dont take much to beef it up to take a ZZ4 tons of people have done this I know for sure Cus my buddie(CamaroMike) has this setup and he runs high 12,s but the trani isnt the big story there its his diff (factory 84 10bolt) thats the weakest link.
Ya sure it is just an RS
B4Cyaa
1991 RS B4C
Former Nebraska Highway Patrol Car
305 TPI
WC T-5
Four Wheel Disk Brakes
Only Options
Rear Defrost
Am-Fm Radio
Red-int White-exe
One BA Of A 350 In The Works
Mods
Dynomax Cat Back (to hold me over till I got the $$$ for the Borla)
best 1/4mile Run of 14.92@94.83
with 145,000 on her
god speed dale
[This message has been edited by 91B4C jacob (edited May 07, 2001).]
B4Cyaa
1991 RS B4C
305 TPI
WC T-5
Only Options
Rear Defrost
Am-Fm Radio
Red-int White-exe
Mods
with 145,000 on her
god speed dale
Transmission: 4L80E/4L80E
For their HO 350 Camaro Conversion (carb and auto cars only), which uses the ZZ4, GM gives you a pressure regulator spring, TV boost valve, and servo piston and housing. If they were worried about the tranny, I'm sure they'd do a lot more.
There are a bunch of TH700's behind BBC's. They can be made to handle the power you're talking about, and a lot more.
If you're really worried about it, give Dana at Probuilt a call.
Yes, that OD is very nice.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/94.6 @ 5800' Bandimere.
