just completed motor swap..have a ?
Old May 9, 2001 | 12:59 PM
formula88's Avatar
i just replaced my 305 for a 355. I took the ac/smog pump unit off, what size belt will i need to run the other acceseries such as the water pump, alternator and power steering? Should i just get the ac delete pulley?
Old May 10, 2001 | 01:27 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Seeing as how you have an 88 im not sure how you could get away with taking the whole a/c and smog pump unit off, i had the smog pump out and quite sure the parts stores carry one for it without the smog pump as for a/c im not sure if there is an idler but there probably is since there is one for the LT1 i put in mine, hope this helps.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
overdriv
Aug 20, 2015 03:52 PM
L98GTA87
Aug 5, 2015 11:02 PM
