need a few parts for my LT4 swap
Old May 14, 2001 | 04:37 PM
havok's Avatar
alright.. the car is almost done. i need to get a vaccuum that will assist my brakes. need phone number where i can find it or parts dealer. i also need a new fan to keep the monster cooled of. any suggestions on a high ouput high quality fan will help. i also need to get my 93 speed density computer re-programmed because i dont think she'll idle very well. i need a little help with these issues and i would appreciate any feedback from board members.. thank you
Old May 17, 2001 | 05:44 PM
poncho9789's Avatar
1) what cam are you running? a roller cam will let you run a more radical cam and not loose vacume. So you might not need a vacum pump.
2) you probally won't need a bigger fan the lt1-lt4 runs vary cool doubt you will need bigger fans. you might go to the autoparts store and get a 4 core radiator that would work beter than fans.
3) are you going to run a maf on your car? if so don't you don't need it if you have a 93 computer it will run on sd and so will the LT-4.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
1nastygta
Aug 8, 2015 07:38 PM
