This is my plan.....what am I missing?
Old May 18, 2001 | 09:38 PM
72Formula400's Avatar
I have the engine and an auto tranny out of a 76 formula that im putting in to my 72 formula until i get the dough to do a nice rebuild of the original block. They're both 400s and I know the 76 is slow, but its better than nothing. Anyway, this is what I plan on buying for the motor. Any reccomendations?
Summit headers
Lunati 1500-5600 RPM cam kit, 275*/.477"
Comp cams double vavle springs
Edelbrock performeer intake manifold + kit
Edelbrock performer timing chain
K&N triangle air cleaner
MSD 6al ignition and msd blaster coil
flowmaster duals with cutouts
Harland 1.65" rocker arms
speed pro forged pistons
Speed Demon 750 carb +fuel line
Holley fuel pump
Thanks guys,
Tom
93 Saturn SL2- Daily driver
73 mustang- 250 6 and 3 speed tranny -lookin for a 5 speed, anyone got one??
72 firebird formula- a weekend warrior in the making-- that is if I ever get the engine together and in the car
Old May 19, 2001 | 05:28 AM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
if you can get your hands on a set of #16 or #670 heads, do that. that will give you a comp ratio of about 10.75. If that is too high for you, the heads on that 76 400 may be better. If they are 6X heads they will work fine on a street car. The 6X heads have larger valves. The 6X is a number cast onto the center exhaust port. But if $$$ is no object, go get some edelbrock heads.
[This message has been edited by zz4mula (edited May 19, 2001).]
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
