Hot Cammed/ZZ4 with AFR 190's
Old May 12, 2001 | 11:17 AM
kermit_one's Avatar
Would this be a decent 12 second setup?Reason I'm asking is goautocenter.com has a zz4 with hotcam and trick flows for $4200,I emailed them about afr's and the said it would be $4500..it sounds like a pretty good deal to me.Is it worth it to go with the afr's?That is with them being 68cc though,the trick flows are 64cc.I know i could have the heads milled down but then the cost is going up quite abit.Maybe I should just go with there Ramjet ZZ430 it's $6300.............
92RS,POLO GREEN
Old May 18, 2001 | 03:43 AM
Norwaybird's Avatar
I'm thinking of getting the ZZ4, and I know it's rated to 355hp with the 58cc vette heads. I'd like to get the ZZ4 short block and some 190/195 AFR heads, but those are 68cc. Would I loose any power due to the redused compression ratio?
Anyone dynoed this ZZ4/AFR combo?
Old May 19, 2001 | 07:10 AM
Norwaybird's Avatar
Anyone?
Old May 24, 2001 | 07:27 AM
91-ZZ4-Z28's Avatar
Yes with out a question it is a 12 sec. setup check out this website for lots of dyno info on ZZ4 with and without AFR heads.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Thaney9
Oct 24, 2015 07:26 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
