Question, i hope u Guru TPI's can help me with???
Old May 24, 2001 | 09:09 AM
vortech305's Avatar
Its sort of a long story, but ill get to the point. Bought this motor in the sig, from a junked firebird which i know was a 305 TPI,and a manual 5 speed. Being the idiot that i am i asked the guy what year the firebird and he said 90'. DIdnt bother to check the vin or see if it was a MAF or Speed density. When i got the motor all i got was the motor harness and computer. MY question is What are the differences on 305 TPI's in 87'- 88'. IM sure to u guys it dosent matter, but im really getting fustrated. I have no clue if its an 87' or 88' PLEASE FOR THE LOVE OF GOD HELP AND DONT MAKE ANY SMART REMARKS. THANK U
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old May 24, 2001 | 09:11 AM
vortech305's Avatar
oh i bought all the emission hardware, i know its either an 87 or 88 so what are the differences in those years.
Old May 24, 2001 | 10:58 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
there is no diffrence between a 1987 and a 1988 TPI intake other than the injector size(19lbs=305 22lbs=350)
1985 throught 1988 TPI intakes are the same(except in 87 GM went with a different bolt pattern for the intake base)
1989 is the same as a 1988 TPI intake except GM got rid of the cold start injector
1990 is when GM went with the SD system
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
[This message has been edited by 91banditt2 (edited May 24, 2001).]
Old May 24, 2001 | 10:17 PM
vortech305's Avatar
Ah great how the hell am i suppose to make a differnce out, with different bolt patterns?? Im sorry like i said im an idiot to TPI's, should of just bough a GEO metro.
Old May 25, 2001 | 07:43 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Why is it important?
Old May 25, 2001 | 01:59 PM
vortech305's Avatar
Well some performance parts say for 82-87 camaros and some say 88-92. Believe it or not and just the though of not knowing what year motor i have is really annoying.
Old May 26, 2001 | 08:50 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
If it is an 86 it will have perimeter bolt valve covers which means it doesn't have a roller cam. It will also have a cold start injector (9th injector). If it is an 87 up it will have centerbolt valve covers meaning it has factory roller cam. Now, if it doesn't have a cold start injector on the TPI, it is an 89up. If the plenum has a MAP sensor on the side behind the runners (or a flat machined spot there with 2 tapped holes) it is a 90-92 engine. 88-92 engines had serpentine belt accessory drives.
Old May 26, 2001 | 05:41 PM
vortech305's Avatar
There seems to be a mistake, I had the motor rebuild, and its a roller cam, i saw the roller lifters. Anyway i checked on back of the computer and saw its an 87-88 not 89. Like i said the reason im asking is cause of performance parts saying for 85-87 camaro or for 88-92 camaro.
Old May 26, 2001 | 08:31 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
speed density plenums have lines on the plenum that dont follow all the way down the plenum maf cars have lines that extend almost to the tb 88 haas a serpentine belt just for giggles you can look at the fuel line extensions on an 88 they wrap under the alternator which is on the driver side 87 and earlier go over the ac compressor.you can also look on the passenger side rear of block by bellhousing ridge to see what it is it will say 5.0L g,h or 5.7L etc.
Old May 27, 2001 | 10:24 AM
vortech305's Avatar
It says GM 5.0L
Old May 27, 2001 | 10:32 PM
IROC5.7TPI's Avatar
If its an 87 or older it'll have a v-belt and serp setup. It will also have a cold start injector,identifying it as a MAF system.
Mike L.
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old May 28, 2001 | 04:45 PM
JoelOl75's Avatar
Thats the only diff I could think of... 87 had the 5 rib serpentine and v-belt 'hybrid' setup and 88s have a single 6 rib serpintine. Both years have rollers, centerbolts and cold start injectors, and maf systems.
89 is maf w/o the cold start injector. 90 went speed density.
Caspar
Jun 19, 2016 11:19 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
