strange question
Old May 30, 2001 | 10:52 PM
JayZ28's Avatar
strange question
Here goes, could I put a 454, or a 502 in my car and still get descent gas milage if I kept(?) my foot of the floor. Obviosly I need to change the drivetrain ext. But, could I put a big block in and still have a daily driver while putting it in 12 or 11's.
Thanxs.
J
speed is a good thing,
more speed is a better thing
86' SLOW LG4 bone stock
except for a K&N
Future Mods: T56
350-383
miniram
Old May 30, 2001 | 11:14 PM
mikeage2's Avatar
if your going to put a big block in,with a 750 cfm carb its going to eat gas i think.mabye im wrong,but i dont think youll get what you want,look at what your little small block gets!it wont be close,but mabye somebody else knows something that will help the motor get better mileage..id keep the small block,body twists enough as it is lol
Old May 30, 2001 | 11:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends. A small block revs higher to provide requred power. Since a big block can supply the same power at a lower rpm there's less throttle required. Now when you go to WOT all those cubic inches will require more fuel to burn. Going from a 350 to a 454 adds 104 more cubic inches to feed. Guestimate about 1/4 less mpg just from that but a big block doesn't usually get bad milage from driving. The poor milage comes from idling.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 31, 2001 | 06:50 PM
BadBowTie's Avatar
Just my two cents worth. A buddy of mine put a 454 in his 83 Berlinetta (got it to pass Ohio E-check as well) and he was filling the tank every trip and a half to-and-from work, where as the 305 it replaced would go from Monday morning to Friday on the way home before it needed to be filled up again.
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Mods:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
Cornholio7979
Sep 20, 2018 02:31 AM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
