The Build Is DONE! 305 to 412 swap!
Old Mar 30, 2010 | 03:48 PM
  #51
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: The Build Is ON! 305 to 412 swap!
How much clearance are we talking about on the bracket? Left in right out on the fuel pump!
Old Apr 5, 2010 | 02:26 PM
  #52
the phoenix's Avatar
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
That's what I thought. Thanks! Fuel delivery is now 100% done.
The bracket is just off enough that if it is bolted to the water pump, you can only see about half of the bolt hole on the block. I could 'wallow' out the hole, but the wall will be so thin, I dont know if it would be the right option or any different than just cutting a c shape.
Old Apr 10, 2010 | 06:59 PM
  #53
A little progress done:
Old Apr 11, 2010 | 07:41 PM
  #54
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Subscribed....
Looking very good Phoenix, your giving me the inspiration that I need. Much like Joe, me very lazy too, but its threads like these that really get me going though....
Old Apr 11, 2010 | 08:18 PM
  #55
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Looks very nice You guys make me want to build a 400 short block.
Old Apr 11, 2010 | 11:33 PM
  #56
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My 412 is still on the stand.
I actually just need to order a flywheel + clutch, and I can put the whole car together. Maybe next week
-- Joe
Old Apr 11, 2010 | 11:34 PM
  #57
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well if you do, make sure you drill the alternate starter bolt pattern in the block, because You'll never get it to work with your T56 if you don't.
-- Joe
Old Apr 12, 2010 | 08:35 AM
  #58
built91Z28's Avatar
-- Joe
Not to hi-jack fromt the OP, but I'm running a Lakewood bellhousing with a 168 tooth flywheel so I could just get a staggered mini starter or see if I could find just the mounting block to change out on my Powermaster mini starter.
Old Apr 12, 2010 | 01:17 PM
  #59
Subscribed....
Thanks!
This is my first ever V-8 build and although I'm impatient, it has gone very well. It doesnt hurt to have family and friends that are able to show you the way.
If it doesnt change, we fire the motor Wednesday or Thursday for initial break-in!!!
Old Apr 17, 2010 | 04:28 PM
  #60
Re: The Build Is DONE! 305 to 412 swap!
Well, it changed from Wed or Thurs, but....
The Phoenix took its first breath today. http://www.youtube.com/watch?v=AROWdyiOuK8
Old Apr 21, 2010 | 08:03 AM
  #61
Broke the motor in on Sunday and talked to my exhaust guy yesterday and she'll be close to driveable when that's all done. (Plan is a true dual exhaust with a Thrush muffler on either side and side exit in front of each rear wheel.)
Old Apr 21, 2010 | 09:27 AM
  #62
built91Z28's Avatar
Congrats on getting her fired up! For me it was so nerve racking starting it up for the first time. I was almost scared to.
Old Apr 22, 2010 | 12:38 PM
  #63
Thanks!
I know what you mean. When I turned the key, I said a little prayer, lol
Old Apr 27, 2010 | 09:08 AM
  #64
Found out that the rear end is actually a posi 3.27 that was a new option for T/As in 85.
Someone told me they had a 3.43 rear with disc brakes, but they didnt message me on a price and now my phone is broken...
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
