where could i find a good 350?
Old May 31, 2001 | 08:31 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey i live in NW indiana....and im thinkin bout either building up my 305 or getting a 350....and i was wondering where i could find a good performance engine that wouldnt cost too much
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
sony xplod cd player,2 12" profile "baja" subs, and a 250 watt MTX amp
$350 for the subs,amp, and box...rattles my car very good!
Old May 31, 2001 | 10:51 PM
firbird's Avatar
http://www.sallee-chevrolet.com/Chev...ckV8s/330.html
I think it is a decent engine and if you want to go a little higher you can get the zz4 crate engine. I prefer the cheep one because I am not going to modify it too much, but if you want to eventually put a lot of power additives I would go with the zz4 just what i think.
Old Jun 1, 2001 | 12:08 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well thanks but i dont have that much to spend either....i was talkin bout like used or new ones that were under 1500
Old Jun 1, 2001 | 05:01 PM
TransAm383's Avatar
Shouldn't be too tough to build a solid 350 for $1500 or less. Here's how I did it when I built my motor up. Start off going to your local junk yard. Around here, 350 cores are a dime a dozen. I got a 4-bolt main version for $150,including core deposit. Take it to the machine shop to be cleaned,bored etc. I paid right around $200 for all my machine work and i was very satisfied. Now check out a PAW ad in HOT ROD or CAR CRAFT. You can order their Super Stock Crank kit for $365. This includes a new crank,rods,pistons,rings,and bearings. Get your self a Jegs catalog. You can get the Edelbrock Performer Carb,cam,lifters and intake manifold for $442. A gasket set should run about $25. I don't really need to go into every last detail, but you shouldn't have any trouble building a healthy 350 on your budget. Hope this helps!
Old Jun 1, 2001 | 06:19 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
oh really
hmmm
well my bro had a guy build him a 355 for like 1200.....so maybe i can go to that guy and see if i could make a deal with him....cuz he didnt charge my bro for labor cuz they are kinda friends and he helped with putting it together
specialized
Jun 18, 2022 09:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
milk
Aug 10, 2015 06:26 PM
